Help - Confused
wmahaffey
Help - Confused
My understanding is that the low kPa values indicate low vacuum and higher kPa values indicate more or higher vacuum. The fuel Map layout seems to indicate just the reverse. Also so does my data logs. When I have a low TPS value I have a low kPa. Example: TPS of 1 to 5 gives a MAP kPa value in the 40 range. TPS in the 20 range under acceleration gives a MAP of Kpa in the 70's.
Where am I wrong?
Thanks,
Bill
- djandruczyk
- MegaSquirt Guru
Re: Help - Confused
You got it a little backawards.. The vacuum levels reported are in KPA and are in ABSOLUTE units. , so 0 kpa = perfect vacuum and 100kpa = atmospheric pressure (well pretty damn close) So low kpa values are considered "high vacuum" i.e. 20" or mercury or more, and high kpa values are LOW vacuum (or closer to 0" of mercury)wmahaffey wrote:I have begun the tuning process. I have run several datalogs and I am confused about what I am seeing.
Where am I wrong?
Thanks,
Bill
Values over 100 kpa indicated boost (pressure) So at idle your KPA values should be fairly low and when you open the throttle kpa values should drop as engine load is increased (essentially speaking).
-- David
jsmcortina
- MegaSquirt Guru
Re: Help - Confused
I think this is a typo. kpa follows load. When you open the throttle the kpa increases.djandruczyk wrote: when you open the throttle kpa values should drop as engine load is increased (essentially speaking).
James
