LPG and Petrol
Posted: Fri May 26, 2006 12:20 pm
by Cooke
I have a car that runs on LPG (but uses petrol to start up with)
I want to know, could megasquirt be used to run both the petrol + ignition and the lpg + Ignition?
Posted: Fri May 26, 2006 11:12 pm
by mitsuko
Yes it's quite possible .
Use msns-e , with patrol on table 1/3 and lpg on table 2 .
Use the table switching feature to switch between two fuels .
And you'll need an extra relay to cut power from inj bank two
when running on petrol .
I've been running this setup for over a year now .
Switching between fuels can be done "on the fly " without the engine even noticing it . No bumps , stalls ets c .
The only issue is that starting a cold engine on lpg is a problem , because megasuirt doesn't do lpg temp/pressure corrections .
But even in winter , I had to run the car on petrol for only a minute or two
before i could switch to lpg .
Pat
Posted: Sun May 28, 2006 10:14 am
by Cooke
So it would be a case of starting on petrol and swapping over to lpg once warm.
How does megasquirt know which set of injectors to use?
Posted: Tue May 30, 2006 7:58 am
by mitsuko
The table switching feature in combination with the extra realy tells megasquirt to fire either bank one ( petrol ) or bank two ( lpg ) .
Pat
