Nissan Lucas Dizzy
Cooke
Nissan Lucas Dizzy
Would this be too much for megasquirt?
I guess I need a pull up resistor. I must say, great timing on this thread becuase I have been brain storming for the last 3 hours trying to figure out why I dont have a rpm signal!!! I can sleep easy now. I don't have an osciliscope, so my diagnostic capabilty is limited.
Thank you very much!
P.S. Maybe we should add the pull up resistor info/recomendation for Nissan optical sensors, in the MS II optical trigger section. In the hall sensor section, A pull up resistor is sometimes recomended...
Cooke
But the basics are, it will work, but you need a pull up resistor (i take it this increases the signal to MegaSquirt) so that megasquirt can realise what rpm the car is doing.
So by doing this you omit the need for a crank angle sensor?
Electronics aren't my cup of tea.
