Acceleration Wizard
scirocco_per
Acceleration Wizard
TPS-Based
11.0 15.0
9.6 9.0
8.0 2.0
8.0 1.0
it is a VW Scirocco 1900cc with Eaton supercharger 11psi in boost and E85 fuel (ethanol) 346cc injector
MSnS-E V3.0 code Extra 029q2
MSnS-E V3.0 code Extra 029q2 Edis4
http://www.scirocco53.net
scirocco_per
I run NB.qadir03 wrote:Kinda hard to tell what is going on with just those values. If you hear a pop then you are going lean, it not and it bogs then you are too rich. It also depends on how fast you press the throttle. Are you running a NB or WB? Look at the log and see what they read as well as your PW.
scirocco_per
Here is the logqadir03 wrote:Post a log, I will gladly take a look at it.
http://www.scirocco53.net/download/data ... 061451.xls
scirocco_per
Why map based, I think the enging rev faster if I have TPS? is it wrong?keithmac wrote:You may want to try mapdot based accel enrichment due to being supercharged?
scirocco_per
Yes I know that I have to small injectors for ethanol E85, I have 346cc injectors and the E85 needs 30-40% more fuel then petrol.qadir03 wrote:Looking at your log, your injectors are pulsing at 25.5ms the whole time you are on WOT. This is NOT normal, unless you have really small injectors and maxing it out.
scirocco_per
