Will MS work with this setup?
thanks
richie
78Spit1500Fed
- Site Admin
What you need to know is; is this ignition system triggered from that dizzy? If so, what is the triggering mechanism? (Points? Optical? VR sensor? Hall sensor?) Does the electronics in the dizzy control the coil directly or is there an external ignition module?
Also, please be specific about what car, engine, etc. this system comes from. The more you give the more you get!
-Brian
