TPS accel problem
tmbg
TPS accel problem
Post by tmbg »
My TPS accelleration rates behave weird, the bar in the accel wizard only moves to about 20%/s when I floor the throttle as quickly as possible. Is there a way to adjust the values it uses for that?
I turned the %/s bins way down, but I was never able to get smooth accel enrichment using the TPS alone; with 60% TPS/40% MAP I was able to get some pretty decent accel enrichment, and it's working pretty well, but I'd like to figure out how to make the TPS rate work properly.
'88 300ZX turbo (SS)
MSII 2.36, v3 board, MT 2.25
Jedrik
Post by Jedrik »
I would ignore the wizard bar and use datalog for tpsDOT value.
Or you can set up at guage in MegaTune.
I typically get a max tpsDOT about 60 (% / .1s) when logging...
shaqjeep
Post by shaqjeep »
The wizard bar is flakey. It seems to lag or miss the event and I have even seen it track my TPS position, not rate as it should! The time it was tracking position and not rate I closed the wizard and reopened it and it behaved properly(?) trying to track rate...though poorly. I suspect megatune's interogation rate is too slow to accurately report many parameters.
I found the default values worked very well, except that I had to double the lowest rate bin, going 1ms to 2ms. This got rid of the hesitation off idle.
Jeep I6 258 GM TBI MS1 V3 MSnS
