Megasquirt No Throttle - Lean (decel)
Posted: Mon Jun 12, 2006 10:40 am
I have an issue on my Porsche 914 with MS II V.3.0 that may or may not be an issue. This is a general question:
From conversations with others I've gathered that most factory cars and aftermarket standalone fuel injection systems essentially shut off injectors on deceleration.
Is this true? From what I've seen megasquirt does not reduce fuel supply on deceleration (triggered by MAP, RPM, or TPS) with the exception of TPSDQ(Decel fuel amount %). It sounds like to duplicate this decel - lean condition we have to setup our tables to do so. Is there any reason to aside from fuel savings?
Reason I ask is that from idle when letting off the throttle my AFR increases, sometimes to full lean. I attached a data log and .msg file. (i've got other issues, unstable idle to deal with as well).
