AutoTune and Target AFR, will it work with MSNS-E, need help
allenvos
using MEGA TUNE 2.25b514 and MSNS-e 024s9a
Ive got the Target AFR tables set and everthing enabled and set properly
including my wideband.
I also put the AUTO TUNE code into my custom.ini file.
I cant seem to get it to work at all. I go for a drive and check the VE tables
and nothing seems to have changed.
Ive got a rough tune setup so I can drive the car but would really like
to use the autotune and TARGET AFR to fine tune and smooth everything over.
I also cant seem to find the autotune check box that everyone seems to
talk about.
Anyone got any ideas on this one?????
Does autotune even work with MS I /MSNS-E???
or is it just the TARGET AFR that will work????
Just getting real frusterated here , and hoping for some help.
Thanks In Advance.
allenvos,I also cant seem to find the autotune check box that everyone seems to talk about.
This was moved to a menu item at some point, look under 'Tools' when on the VE tuning table item (the 3-D version).
Autotune does work with all MegaSquirt variants, including MSnS-E, if configured appropriately. You may have to use the above menu item to enable it.
