Flashing Table Entries in MegaTune
Going through the initial setup in MegaTune, and when I generated the VE table, two of the entries started alternating which cell was highlighted. So, the table entries sort of flashed between being highlighted in green, and not. This is the latest version of MegaTune. I've attached the vex file for the VE table. The AFR and Ignition tables are doing the same thing in the same cells (100kPa, 5000 & 5500 RPM).
-Patrick-
'04 SRT4 - Daily driver
In MegaTune 'table' view, the current kPa, rpm, and VE value are higlighted in green. These often bounce back and forth in a real vehicle, and can do so on the stim as well (especially with MS-I and it's 100 rpm resolution - if the rpm is set to 5250 - it can bounce back and forth between 5000 and 5500 in your case).
