How to use non-GM sensors?
Posted: Sat Jul 15, 2006 11:17 am
by sindre
I have MS-II V3.0 code2.34
I'm going to use VW CLT and Volvo IAT. So I have started with the coolant.
Is It just to find ohm in 3 tempratures and push it into Table Generator in megatune?
What should I set in Bias Resistor Value(ohm)?
Posted: Sat Jul 15, 2006 12:03 pm
sindre.
Yes.
The default resistor is 2490 Ohms, so unless you (or someone else) changed it, that's what you use.
Posted: Sat Jul 15, 2006 2:24 pm
by sindre
Ok, thanks. have not changed any resistor so it should be right then.
Posted: Sun Jul 16, 2006 2:11 pm
by max@zl2max.gen.nz
Just a bit more on Lances comment about bias resistors
Isn't there a note somewhere that says the bias resistor is equal to the sensor temp at 27 deg C ?????
Max
Posted: Sun Jul 16, 2006 7:46 pm
Max,
You can do that instead of changing the temp tables, but it so easy to change the tables with MS-II that I don't think any one bothers with changing the bias resistors.
Posted: Mon Jul 17, 2006 5:27 am
by FoundSoul
Here's a little tech article we put together a while back on getting the proper readings to enter into MegaTune....
http://www.diyautotune.com/tech_article ... lation.htm
