constant speed surge
I am having problems with a surging at constant throttle. It does not matter what RPM if you hold the throttle constant for a little while the car will eventually start a light surging. If you get on the throttle at all even very little it pulls nice and smooth. The AFR is not ranging far enough for lean conditions.. at I don't think it is I have not had a good data log yet. What else would cause this?
mops
- Experienced Squirter
So I looked at the datalog and all of my signals have what looks to be a good bit of noise, I changed the grounds for my EDIS to another place on the block, I have the MS and IAT, CLT grounded to a different spot on the block and tried moving my +12 wire directly to the battery just to see if it helped..No change
What should I be looking for to reduce noise across the board? Does EDIS require the dave cap or C30?
One other question I noticed when I hooked up the MS directly to the battery the injectors are making a clicking noise? I thought the injectors were fired from ground through the MS why would they energize when the MS is powered up?
The car runs pretty well other than this.
I can upload a datalog file but i need a host?
Scott
mops
the way to fix grounding issues is to connect ms with all sensors, including lc-1 (if you have one) to one common ground, and the run a wire from that point to battery negative.
noise on all sensors can be caused by flustuating battery voltage. if your alternator is on it's way out it can fluctuate hance all the sensors do wierd things
to fix unwanted accel enrich incerase AE treshold and that will fix your problem for now
As of last night I had some real improvement, I rewired all of my sensor grounds to pin 19 on the MS, Ran the other MS grounds directly to the block, and moved the EDIS ground to another point on the block. This cleared up all of the problems with AE kicking in. also moved the LC-1 analog grounds to the block with theMS. Datalog now looks really clean
I know this is more in the lines of wiring and sensors so I will move my other questions to that board.
Thanks again!
Scott
