Injectors that point backwards!!!!!
Pilninggas
I'm a newbie presently fitting a ms2 to an FZR1000 motorcycle. I am trying to save myself agro' by using gts1000 tbs ( straignt fit) and Bimota YB11 manifolds with their matched Weber Marelli injectors (308cc/min) - also a straignt fit. Anyway what is bugging me is why the injectors point back toward the tbs. I'm guessing its to aid charge mixing at low loads/rpms, but it still seems a little wierd. Has any one seen this before/does anyone know why the injectors are arranged in this way.
Cheers Merv.
Pilninggas
Well if Bimota did it it must have flow benefits, glad to know that this is a better way and that pointing towards the valves is considered a compromise - cheers BowBow wrote:According to popular belief by engine tuners, this is the best way to get a good air/fuel mix..
However, since it is not very manufacture-friendly to build that way, most do not do it.
detcollector
Not good on cold starts means:-
Bad for emissions.
LOTS of extra fuel required for priming, cranking etc.
Problems with fuel puddling when cold.
Typically a usefull solution for racing vehicles.
