Air Density Correction
TV Super Bee
Post by TV Super Bee »
MSI V3.0 MSnS-e029q2
My AFR is perfect if my engine temp is below 190deg F. Above this temp my EGO goes lean. In the Advanced settings of Megatune this can be adjusted % up/down. The manuel does not say which way to adjust for more fuel at a given temp. In the morning and evening the AFR is perfect, during the day ambient temp can rise above 100deg F. this in turn makes my CLT & IAT rise leaning out my engine. I live in California, at sea level. The Megamanual only describes these sensors and does not address how they function with Megatune. Please help!
1969 Dodge Super Bee
383 EFI dual 65mm throttle bodies, 36lb injectors
"AS SEEN ON TV"
http://www.moparalley.org/gallery/hollywood
TV Super Bee
OK, I contacted Phillip at the Extra siteand was told to adjust % up for more fuel at a given temp. It's very hard to dail in VE when the tempature swings low/high during the day. This may seem silly but the megamanual does not describe this feature at all.
"AS SEEN ON TV"
