Fuel only in MS II
AfricanDubber
Fuel only in MS II
Post by AfricanDubber »
Hello,
I am trying to implement MS II V3 to control a VW 16V. I'd like to control fuel first and keep the OEM ignition before moving to Spark control when I am more comfortable with the system. Two questions:
1. Can the ignition control be disabled in MSII and does it matter?
2. I get tach signal from the negative coil and it seems to work fine. Are there any problems on continuing this way for some time, knowing the board was assembled to trigger with a Hall signal?
Thanks.
simonbos
Post by simonbos »
I am running fuel only using the signal from the coil to trigger my MSII. It seems to work fine.
AfricanDubber
Fuel only in MS II
Did you diable the ignition control. If so, how?
