Hey all - trying the "one size fits all" VR input for everything. Today I tried a coil negaitive input from a running HEI external coil (stock 'Tach' output wire on coil). Instant success! However, the rpms bounce rapidly (jitter) about 800 rpm up and down at fast idle (1150 to 1950ish).
I started with R52 & R56 fully CCW and could get signal with the hysteresis in any position but lost the signal with R56 voltage pot about 13 turns CW. JUST before I lost signal I got a clean rpm reading. Super sensitive and if I breathed on it I'd lose signal.
I need this to work quickly so I need ideas. If I can't get a clean solid signal easy I'll probably get it from the 7-pin module R terminal. I'd like to get the coil (-)/VRin working though.
I'm trying to do the same thing with using the - side of the coil going to the vr + input on the MS.
But I can not get a clean rpm reading.
I have tryed to ajusting the r52 and r56 with no luck.
I'm useing MS1 V3 fuel only.
What else can I or should I try?
89,88,87 Conquest TSI
1971 Jeep CJ5
MS1-V3 Fuel only MSnS Extra on a 2.6l turbo for now...
I have tryed a few more things today.
I had the shelding for the tac wire grounded on both ends, so I changed to to jest one end. It didnt change anything.
I also added a wire to pin #7 and went to ground with it. No change.
The car will start and run, but the rpm's in MTune are all over the place from Idle to 8000 rpms when the car is at a idle.
At 1200-1600 the rpm's in MTune has a stedy rpm reading.
Is there some thing I have over looked? or do I have to chang it to the hall?
OH.. I'm running B&G v2.0. Should I try a newer version?
Thanks.
1971 Jeep CJ5
