Old US DIY-WB O2 settings?
PSIG
Post by PSIG »
I found a misplaced DIY-WB kit from a few years ago for the L1H1 sensor. This is the old USA version. Once I get it built which O2 should I select in MT2.25 to get a good match? I want to try it in the current project with an MS1/029s/v3/mt2.25.
Don't ya just love re-finding stuff? Now if I could find that $100 bill I stashed... :lol:
TIA,
David
cosmo1stgen
Post by cosmo1stgen »
I use to have the old one v 1.5. From what I remember when I had mine the voltage output was non linear from 0-4 volts. I dont think megatune supports that. If the diy wideband website is still up they use to have a graph that ploted what voltage represented what afr. You may be able to program that plot into megatune custom ini.
PSIG
Post by PSIG »
Thanks for the reply! I realized that the documentation in both the MegaManual and the MegaTune pages refers to the US version I have. I had assumed (doh!) that it referred to the later Australian version. All set!
David
