alternate edis coil packs
Posted: Tue Aug 01, 2006 11:58 pm
by cwest
As the header suggests does anybody know of a proven alternate that uses a standard type of plug connector at the coil instead of the specific ford one as they are impossible to get here and i need to reconfig my ign leads
TIA
Posted: Wed Aug 02, 2006 12:58 am
by PSIG
Most waste-spark coils will work. I know Chrysler family coils do.
Posted: Wed Aug 09, 2006 9:43 am
by turbo54
Will the standard two-post GM ones work? Is there any documentation on how to do it you can point me to?
You can try this
Posted: Sun Aug 13, 2006 12:21 pm
by Karl
Just solder the wires to the coil pack and then put a few thick coats of electrical "tape" paint on it.
Posted: Wed Aug 16, 2006 5:49 pm
by tlivingd
so in using the GM pack just jab something in the slot, for wire one and something in the other slot for wire 2? there is no other connection to these coil packs?
using MS2 V3 board
-nate
Posted: Wed Aug 16, 2006 9:47 pm
by PSIG
See if this helps: http://www.teglerizer.com/fi/megasquirt ... odule.html
In this case he is firing the coils with VB921's instead of EDIS, but removing the GM guts would be similar.
David
