Flow rate testing, How?
Avinitlarge
Post by Avinitlarge »
How can I check the flow rate of some injectors I have??
Megasquirt V2.2 main board
MegaTune 2.25
Extra029T
Innovate LC-1 Wideband Lambda
http://WWW.MONDEOTURBO.COM
Ferret
Post by Ferret »
Basically it involves attaching the enjectors to a fuel rail, FPR and pump, just like in a car, turning everthing on with the injectors pointing into a cups/bottles or any other suitable containers and measuring the amount of fluid collected over set period of time.
Avner.
Avinitlarge
Ferret wrote:Basically it involves attaching the enjectors to a fuel rail, FPR and pump, just like in a car, turning everthing on with the injectors pointing into a cups/bottles or any other suitable containers and measuring the amount of fluid collected over set period of time.
Avner.
any Idea what the set period of time could be?? I belive the injectors could be 440cc but im not 100% sure, I would like to test them just to make sure
MegaTune 2.25
Extra029T
Ferret
Post by Ferret »
440cc means 440ccs of fluid per minute (usualy measured at 3 bar of pressure), but you can run the test for let's say 30 seconds and multiple the amount of fluid by 2 to conver to cc/minute.
Avinitlarge
Ferret wrote:440cc means 440ccs of fluid per minute (usualy measured at 3 bar of pressure), but you can run the test for let's say 30 seconds and multiple the amount of fluid by 2 to conver to cc/minute.
I thought thats what it was, Just wanted to make sure
MegaTune 2.25
Extra029T
Avinitlarge
Ferret wrote: 440cc means 440ccs of fluid per minute (usualy measured at 3 bar of pressure), but you can run the test for let's say 30 seconds and multiple the amount of fluid by 2 to conver to cc/minute. I thought thats what it was, Just wanted to make sure Thanks Image
Megasquirt V2.2 main board MegaTune 2.25b717 Extra024s13 WWW.MONDEOTURBO.COM
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135508#135508 -------------------- m2f --------------------
Posted by email.
MegaTune 2.25
Extra029T
Mk1rocco
Post by Mk1rocco »
Avner.
I've got a follow up question. What's the longest amount of time you can run an injector at 100% without damaging it? Or, is it neccessary to hook it to some circuitry which mimics the ecu providing a pulse train with fixed duty cycle preferably less then 85%?
Ferret
Post by Ferret »
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135502#135502 -------------------- m2f --------------------
Posted by email.
Avinitlarge
Posted by email.
MegaTune 2.25
Extra029T
woh
Post by woh »
