need help on a 91 mustang
Posted: Wed Aug 09, 2006 12:54 pm
by sidewayzisbest
I am running 2.25 on MS-1E , and having problems starting it up. It is a N/A motor with heads/cam/and other stuff. At idle its reading 80-90 KPA wouldn't this be too high for idle? What would cause it to be so high?
not sure if i uploaded this log file right though....
Posted: Thu Aug 10, 2006 1:26 pm
by RNash
What is your MAP source? What does it read with a vacuum gauge? The first thing I would check is if your MAP is reading correctly compaired to engine vacuum. 80 KPA is only aroung 6 inch lbs of vacuum. Is that what you are running?
Posted: Sun Aug 13, 2006 5:45 am
by sidewayzisbest
91 gt bennett racing cam, ported tw heads, dss 306 pro lite bottem end and bunch of other bolt ons
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135493#135493 -------------------- m2f --------------------
Posted by email.
Posted: Sun Aug 13, 2006 3:30 pm
by S.Bretz
I mean cam will cause a low vacuum at idle....but so will a leak in a vacuum line. First instpect you lines....or get new ones, to insure that you don't have a leak.
Low vacuum is a result of a high duration cam. You can try to bring the vacumm up by leaning it out some and adding spark advance.
