Make a V8 idle and run. Engine runs, but not perfect. Help!?
The engine will run with twinturbo soon, but now I do not have turbo instaled.
So I have bought 8 large low amp. injectors, 72lb/hr, that I am planning to use with the twinturbo setup for 7-800 hp.
But now I have about 400hp, so now I have eigth 42lb/hr injectors that I use.
I have tried to tune this, but cant make it idle, and after some startup hours, the car totally stopped, and never ran again.
I checked the plugs, and they where all dirty and still wet of gasoline.
What shall I do to tune it right for a trip on the road?
What I did was just estimated the base number...or about what I thought it would put out at what rpm and pressure. It doesn't matter if you are off 30or 50hp up top...it will be pig rich anyway.
Next, get it to idle...which you did. It will be super rich. go to the table transform pull down and start multipling it by .75-.8 at a time until you get close....WHen you get close, the rpms should shoot up and it should stop sputtering. Once you get it close, Select the "goto" feature in the fuel tuning window and just follow the rpm's around and adjust up or down depending on your A/F ratio's. Once you get a few spots that are good, you should be able to start to see a pattern of how the map will look in that area. Adjust the area and go from there.
Ok....this is just incase you are known to do brainless stuff every once and a while like myself...Did you plug the vac hose into the MS unti?
IF YOU DON'T HAVE A WIDE BAND THEN BUY ONE. YOU CAN'T TUNE BLIND.
I changed to 42lb/hr injectors, and the engine started again. It went for a coupple of minutes, and then I turned it off.
After this the engine did not start again, because the the plugs where all wet of gasoline. Then I washed them, and tryed againg, but it never started...
So, the engine gets to much fuel.
How shall I set it up, so it don't gets to much fuel?
Can someone help me with a setup that will idle, and start after a stop?
The enigne is a 302ci V8 with about 400hp. I have 8x42lb/hr injectors, high imp. (16 ohm).
Please help...
I'll leave the running issues for others with more experience.
jack
. . . . . . . Mark Twain
Try chopping the ve table down until it runs right by using the table transform feature in the TABLE->VE1 screen.
Aghhh, here. try this. I dropped the VE at idle alot.
Rolling_Thunder
actually the injectors are 35 lb/hr... just checked it now. som they should be perfect!Rolling_Thunder wrote:from what i know - the 42 lb/hr injectors are a pretty good injector - but possibly too large for your current application - this is why your plugs (and rings) are getting washed... 400hp you should need around a 32lb/hr injector...
Im new to the whole EFI thing - but its just a thought
