the flywheel is on the left, as well will the two larger teeth make any difference?
I have a 1981 928S with a 1986 engine in it, this engine uses a hall sensor on a 100-1 flywheel arrangement with the missing tooth being 90 deg BTDC, however this ring is just a press fit and can be removed, or slid to a new orientation,
I could remove it and have a custom ring made with X # of teeth, but if you have ever replaced a dual disc clutch on these cars you would know it is not my first option[/url]
