http://euter.ftux.com/IMG_4920.JPG
I thought mabey it was a leaking injector, but after the car is shut off, the fuel pressure stays pressurized for quite some time.
The car runs, but it is very noisy, runs very rough, back fires with any touch of the gas pedel.
As of right now i am running MS&S, here is the datalog of when it happened, and also my MSQ just in case you wanted to have a look at it. I am running a top feed rail with mustang #42 injectors set at 65 psi base FP.
Datalog:
http://euter.ftux.com/ryan69.xls
MSQ
http://euter.ftux.com/After%20car%20stopped.msq
Make sure you right click the link and save as.
Took the intake off today and this is what i find on the intake and the heads:
I also did a compression test, and this is what i get:
1=185
3=190
5=190
2=185
4=185
6=180
So i am getting decent compression, doesnt seem to be any bent valves, ive swapped the spark plugs, spark plug wires, injector connectors, and still i cannot get this cylinder to fire. The oil on the intake also scares me!!
If anyone has any idea's i am open to pretty much anything at this point!!
Ryan
