How stable should AFR/Lambda be at idle?
hobieboy
Post by hobieboy »
As the title said... in my case, my AFR oscillates between 13.5 and 12.8 (yes - I want to start with running way rich as I need the engine to be around 11.9 at full boost).
Is that too much variance? What typically will make it more stable - timing/fuel/...?
thanks.
TPI 85 Blazer
Post by TPI 85 Blazer »
Is map or rpm changing so that the VE is changing?
hobieboy
Post by hobieboy »
Actually, nothing seems to be changing. MAP is very stable. The VE is changing maybe by 1%; probably due to RPM changes.
