setting up fuel cut
setting up fuel cut
I am not to sure what these settings refer to
Kpa lower than and TPS lower than( raw adc)
Keith
The fuel cut settings are to be sure you get cut on decel but only at levels that won't cause stalling or false triggering. I set the kPa somewhere between my idle kPa and the lowest Kpa I normally see during typical driving. On the V8 I'm tuning now, it idles at 28 to 30kPa and throttle-closed decel is at or under 20, so I set my 'kPa lower than' to 25. Works well around town and doesn't cut in and out during smaller throttle changes in traffic - although some set it that way.
For the 'TPS lower than' setting, get your closed throttle ADC count by doing a TPS calibration under the Tools/Calibrate TPS heading. On my example truck, I get 27 with my foot off the pedal, so I set it to 30 to be sure it only activates on hard decel, but has a bit of slop factor for the throttle linkage and such.
David
