MSII with EDIS, Timing Fluctuating with SAW disconnected
jsmcortina
- MegaSquirt Guru
James
EDIS unstable
Pls make sure :
Sensor fastened on to the block and totally stable
VRsensor plug fully inserted and shielded VR wires .Route away from HT leads
0,25µF capacitor between coil pack plus, close to the coil and solid ground
Total HT resistance in each circuit ( ie HT wire +plug) 5-10 kiloohms
i.e resistor plugs and or resistor HT leads
Make sure that the 36-1 tooth wheel is connected solidly to the crankshaft , ie NOT on the vibration damper ring . The vibration damper will oscillate at certain RPMs and distort the VR sensor signal , leading to erratic sparking
Good luck
Heribet
