15psi boost = blown injector fuses
I discovered that both of the 5amp injector fuses in the relay board had blown. Any ideas why this happened? Unfortunately, I wasn't data logging at the time (of course...). I thought someone might have some thoughts?
MS-II, v2.2 main board, relay board, EDIS, 38lb injectors @ 3bar, 2.0L turbocharged four cylinder, wideband (no correction at the moment), v2.36 megatune
EDIT - here's an attachment of just running around the block. Maybe something sticks out? Other than being very rich everywhere (just started tuning!)
jakobsladderz
Duncan
Thanks for the feedback. From my latest run around the block, I got an 72% duty cycle at 196kpa, 5073rpm, 72% throttle, and 10.8:1 AFR. So yeah, you're right about maxing out the injectors! Even after leaning things out, it looks like I need to step up the injector output.
However, I'm using standard issue Bosch "brown top" injectors (from a Merkur, among others) which should be regular high-impedance.
Could the fuses have blown from simply pushing the duty cycle too high?
Looks like injector-shopping time regardless
BottleFed70
jakobsladderz
I'm trying to get a set of stuck rings to seat (new motor was assembled then sat for a year +). Nothing has worked so far, so I thought I might hammer on it a bit before conceding and pulling the pistons out for a re-ring.
Rather than messing with the low impedance injectors, which ultimately can't supply enough fuel, I'm looking for high impedance replacements at a slightly higher delivery rating (started another thread in the injectors/fuel/etc. forum).
Thanks all for the help, it's been invaluable as usual!
