Is it possible to run dual IACs off of a single MegaSquirt?
I can either run dual IAC valves or plumb a single remote one into the old starting carb tube-manifold underneath the intake.
I would much rather lose the tubes. They are a major pain.javascript:emoticon(':evil:')
Is it possible to run a pair of IAC valves, splitting the signal wires so that they are run in parallel?
I figure it will either work perfectly or not at all.
Help me out here.
3.0 board, MSII, jumpered for IACs.
jsmcortina
- MegaSquirt Guru
Another alternative for the more electronically minded would be to duplicate the IAC driver chip circuit so you have equal current driving capability.
James
78Spit1500Fed
- Site Admin
