O2 Volt gauge
Scott Bruce
O2 Volt gauge
I'm using a MS-II with I believe version 3.0 software. Isn't the o2 gauge suposed to go up to .9- 1 volt when you put your self in series with the sensor input wire and 12V pos? It only goes to .4 volts. ( I was taught to use a 1.5 volt battery or put your self in the circuit). I get cross counts but it never goes up to .5 or higher. any ideas? Just to make sure, The sensor used is just a universal sensor correct? It doesn't use the sensosr that changes resistance.
Thank You
Scott Bruce
1969 Turbo Lotus Europa
There is a bit of a bug in some versions (up to 2.36) of the code for EGO (more accurately, there is a 'misunderstanding' between MS-II and MegaTune as to what the narrow band curve should look like).
Try setting the EGO to one of the WB (I set it to DIY-WB), then shut down both MT and MegaSquirt. Then fire them both up again and setting the 'calibrate AFR table' to narrow-band - be sure to press 'okay' - just because it is already highlighted doesn't mean you are done. Cycle MT and MS again, and see if it is better. This has worked for me.
Scott Bruce
O2 sensor
Another question, has any one found a fix for the idle air control so that the car will idle down after a cold start with out having to restart the car?It never start, warms up and idles down with out a restart
Thank you
Scott Bruce
Scott Bruce
o2 sensor
are you saying the latest code for the idle control or both of the problems
Scott
