Which one to tune first? PWM current limit or thres... HELP!
Posted: Mon Sep 04, 2006 1:13 pm
I'm still having trouble with the low-impedance injector. With settings of 75% and 1.0ms it workes ok, but after some test driving the engine will start to cough. This was occuring very early a while ago when I had slipped the default time threshold of 25.5ms into play. So I think something is still causing the injector to heat up, etc...
So to tune the injector should I first start with the PWM current limit and set it as low as I can. After that the same thing with the time threshold or should it be done vice versa?
The injector is a bosch 0 280 150 651 with impedance of ~1.3 ohms. One odd thing is that after I played with the time threshold A/F started to go VERY rich (plugs went pitch black)). I had it around 0.6-0.7 and I could not tune the engine leaner anymore?!. This is also weird becaude I made some calculations today and realized that I have used a way too low req_fuel value.
The injector flows 611.4 g/min (80.87 lb/hr) @3bar (43.5 psi) 100% duty according to one source (not bosch). I'm using only 1-1.2 bar (14.5-17.5 psi) of pressure so it should flow around 50 lb/hr at 100% duty. Lower it to 80% duty it should flow around 40 lb/hr.
In a 1.3 liter (75hp) engine it will give 5.2ms of req_fuel. I have been using 3.0-4.0. How can the engine go richer after lowering req_fuel and PWM time threshold?!
It's probably possible that the injector took some beating after the HIGH time threshold setup. Maybe I'll go and buy a new one... I was thinking of buying a less flowing injector. With the calculations above I should get idle pw around 1.5. The same injector is used in a 75 and 90 hp Golf 1.8 engine and also in a 1.6 Seat 70hp engine. So how big role does the displacement play becaude I have 75hp but 1.3 liters?! I could get the injector from a 60hp 1.4 Golf that flows 29 lb/hr @1bar and 80% duty (446 g/min @ 3bar 100% duty) or a 1.4 liter Fiat 32.5 lb/hr @ 1bar 80% duty (506 g/min @ 3bar 100% duty). These could give me around 1.6-1.7 ms idle pw. Sounds good but a injector size calculator gives a maximum of around 50-55 hp? Where am I calculating wrong?!
Any opinions how should I proceed?! Thanks a lot of your help!
