can i share vr sensor with stock ecu and megasquirt ?
spyro
Post by spyro »
i want to share the same sensor with the stock ecu and megasquirt
is this possible ?
spyro
Post by spyro »
oops posted on wrong forum :(
PSIG
Post by PSIG »
Hi spyro -
Generally, yes. AAMOF, all the sensors can usually be shared if they don't have some weird controls applied from the OEM ECU or low resistance inputs. A shared install that's in-progress here includes a GM ECM that is retained for electronic transmission control. I would have shared all the sensors, but the CLT sensor gets a bias resistor switch at 120°F that made sharing a pain. Just added a second sensor for MS and no problems. Image
David
sparkandfuel.com
Post by sparkandfuel.com »
A lot of toyota sensors can share signals and never have a problem, almost any resistive sensor will be fine from my hands on experience. I have heared of some users not having a good experience with shared sensors but that may be on a case by case scenario. I would say try it out and if it does not work out then you know what to do.
-gary-
www.SparkandFuel.com
----- Original Message -----
To: megasquirt-ignition@msefi.com (megasquirt-ignition@msefi.com)
Sent: Tuesday, September 05, 2006 3:21 PM
Subject: can i share vr sensor with stock ecu and megasquirt ?
Hi spyro -
David
This post is at:
http://www.msefi.com/viewtopic.php?p=141024#141024
Posted by email.
