Is it true that race engines don't use vacuum advance?
I would think that most are disconnected on race cars just because it is just one more moving part to fail and it would rarely be used during a race as most times these are full throttle conditions. It may also have something to do with compression braking too. I think most road racers do not like much as it upsets the balance of the car so they depend more on the brakes for slowing.
Todd
Most true race engines don't use vacuum advance. They don't need it since fuel economy isn't usually a consideration, and it's just one more thing to fail.
In fact, quite a few race emgines don't use mechanical advance either. The reason is that since most timing curves are at their maximum by about 2800 to 3000 rpm, and most race engine operate well above that, there's no real ned for changing advance. This does make for hard cranking and starting, and a rough idle, but also eliminates potential failures and makes it easier to be sure that the advance you set is the advance you get.
