looking for a spark base map for V8 ford
Posted: Mon Sep 11, 2006 9:59 am
by 65looter
Hello everyone,
I am after a base map for a V8 Ford (342 stroker, but 302 will do)
If anyone is using such engine, please can you post your map?
Thanks a lot
Stephane
Posted: Mon Sep 11, 2006 10:44 am
by cscm094
Posted: Mon Sep 11, 2006 11:03 am
by 65looter
thanks, I had seen that link.
I am after a map being used, I have tried the calculator from
http://planetcampbell.us/IgnitionAdvanc ... timate.sxc
and I am getting some weird results.
KPa
100 16.0 16.0 20.0 24.0 28.0 32.0 36.0 36.0 36.0 36.0 36.0 36.0
80 22.0 22.0 26.0 30.0 34.0 38.0 42.0 42.0 42.0 42.0 42.0 42.0
70 25.0 25.0 29.0 33.0 37.0 41.0 45.0 45.0 45.0 45.0 45.0 45.0
60 28.0 28.0 32.0 36.0 40.0 44.0 48.0 48.0 48.0 48.0 48.0 48.0
55 29.5 29.5 33.5 37.5 41.5 45.5 49.5 49.5 49.5 49.5 49.5 49.5
50 31.0 31.0 35.0 39.0 43.0 47.0 51.0 51.0 51.0 51.0 51.0 51.0
45 32.5 32.5 36.5 40.5 44.5 48.5 52.5 52.5 52.5 52.5 52.5 52.5
40 34.0 34.0 38.0 42.0 46.0 50.0 54.0 54.0 54.0 54.0 54.0 54.0
35 35.5 35.5 39.5 43.5 47.5 51.5 55.5 55.5 55.5 55.5 55.5 55.5
30 37.0 37.0 41.0 45.0 49.0 53.0 57.0 57.0 57.0 57.0 57.0 57.0
25 38.5 38.5 42.5 46.5 50.5 54.5 58.5 58.5 58.5 58.5 58.5 58.5
20 40.0 40.0 44.0 48.0 52.0 56.0 60.0 60.0 60.0 60.0 60.0 60.0
500 800 1000 1500 2000 2500 3000 3500 4000 4500 5000 6000 RPM
Posted: Mon Sep 11, 2006 12:17 pm
by boost junkie
That's quite a bit of spark advance. Might want to drop all of those numbers by at least 10.
Posted: Tue Sep 12, 2006 5:33 pm
by BottleFed70
The advace looks good for the high KPA map areas, but might be a little much for the low KPA areas.
