Microsquirt GSXR1100 Turbo
Posted: Fri Aug 31, 2007 2:04 am
Hi,
Newbie post i'm afraid....I've got a Microsquirt ECU winging it's way to me as we speak (I've been eagerly awaiting the launch for about 2 years!).
The Bike is an old ('86) GSXR11 with the later ('91) 1127 motor. It also has individual thottle bodies, fabricated plenum, blow thru turbo setup with a huge FMIC. I've gone for standard sensors / hardware that I have prior experience with. These are namely :
Bosch NTC IAT & ECT sensors
Ford VR crank sensor with a lasercut 36-1 crank mounted disc
Weber Marelli (Sierra Cosworth) 2bar MAP sensor
Original TPS
2 Double ended "Dyna" 3 OHM coils
I guess the crank trigger & coolant/air temps sensors should be easy enough.
The question I have is around the MAP sensor I am using. I assume I will need some form of calibration table for the sensor? (should be avaialbe o the web somewhere) The standard MS sensors seem to be 2.5 Bar, 3 Bar or 4 Bar. Has anyone used this type of sensor before? I could swap to the generic GM sensor but the Weber one is munted & the harness is made so would mean redoing it all.
Any Ideas?
Thanks, Stewart.
Original TPS
Any Ideas?
Thanks, Stewart.
