Question: Can I use a custom trigger wheel (like a 60-2) and use the dual output ignition for waster spark? (the same way EDIS does it but without EDIS ;) )
Reading the Dual Spark table 3a I think that it should work. It says
So, using a custom trigger wheel, and then a coilpack from for example an EDIS enabled car, connecting each coil to a seperate output should work, right?M-N crank wheel | Single crank wheel input | M (≠0) | N (≠0) | Input 1 n/a Output 1/2 alternate | 4-cyl wasted spark, crank trigger and no cam trigger
/Carl
