More yamaha help needed (fixed)
pommie02
i have hooked it up to my tacho out put wire...but i have no signal.
i am using the latest code..all of the other gauges are working,
do i have to set anything in megatune..i am only using it for fuel control..no ignition
regards Gary
SQLGUY
- Experienced Squirter
Re: More yamaha help needed
If it's a Hall effect sensor, you'll need to build an extra circuit to process the signal.
If it's a variable reluctance sensor, it should work just fine, but there is a known problem where some Microsquirts have the shield and center wire VR in pins (pins 32 and 33) reversed. If the shield on your VR in wire is going to pin 32, you could either try reversing the connections at the pickup or swapping the pins in the Ampseal connector.
pommie02
I am using the tacho signal wire...its the grey wire. both of the coils have a permanent live and are triggered by 2 seperate wires. the grey one goes through a diode block...which i assume alters the signal. i have disconnected the tacho, to eliminate any noise. i have also tried both of the option wires....but still no good.
i would use the crank sensor...but the crank only has 7 markings on it..
just another thought...can i use a inductive pickup..directly off of one my plug leads...the same as they use on a timing light. i know you can buy tacho's that run from a lead
Thanks Gary
SQLGUY
All of this is assuming your ignition setup is similar. Also, make sure to connect to the inputs to the TCI box, and not the lines running to the coils. On mine there is a six pin plug that includes the inputs, and a four pin one that connects to the coils.
If your setup is not similar, check your schematic to see where the ignition module gets its timing signals.
Cheers,
Paul
pommie02
the wires you are talking about..are these the option + and -.
it sounds like the wiring is very similar, my grey wire is for the tacho, i have orange and grey going to the coils. i have a small black box in top of the ignitor which has a 6 pin plug with grey wires coming out of it.
are you saying to use both of the option wires...one to +ve and the other to -ve
thanks gary
SQLGUY
On mine I'm using VR+ and VR- (pins 32 and 33), not Opt. If you're only using uS for fuel, I don't think you'll need to hook up both VR1 and VR2; just the VR1 input should be sufficient for RPM information for the ECU. I'm using both VR1 and VR2 since I am controlling spark as well as fuel.
Cheers,
Paul
pommie02
i used the VR wire...and it was the wrong way round.
now i have a tacho...and it brings in the fuel relay aswell
thanks mate..
regards Gary
- Master Squirter
Glad you're sorted now, but you could have used the crank sensor, it's an 8-1 sensor wheel as far as a µS is concerned. My Yamaha GTS1000 has only four dimples in the crank, but uses a crank sensor too. Yamaha 4 cyl bikes of our vintage all use grey & orange wires for the two ignition coils, and as you noticed, they use the grey one to feed the tacho.pommie02 wrote:Its A 88 FZR 1000...snip ...i would use the crank sensor...but the crank only has 7 markings on it..
Perhaps, you could PM me later, as I'd be interested in your progress & settings, because I am going to fit the µS to a Thunderace engine (same crank markings as a FZR) after I get the GTS running.
Cheers
pommie02
Re: More yamaha help needed ( fixed)
i might try the yamaha pickup... the bike is nearly ready to run, once its runnig, i will give it a try..
regards gary
Dave Sloan
When is the start up?
Cheers
Dave
