flood clear settings
pommie02
i see that the flood clear voltage has a default setting of 3.5 volts.
does it mean over that voltage that the injectors will not inject?
do i need to alter this setting ?...and if i do, is it 12 volts ?
SQLGUY
- Experienced Squirter
Re: flood clear settings
You would need to adjust this if your TPS voltage isn't above 3.5V at WOT. It would never be 12V, as the TPS gets VREF from the ECU... the max TPS voltage would never be above VREF (5V).
