Cranking speed
pommie02
Cranking speed
do you set it to below your actual speed or over ?
i ask this because is this the point when the ecu switches from cranking to running ?
Re: Cranking speed
Re: Cranking speed
Just to add a bit to what Al says, you want to set the cranking speed *above* your actual cranking speed because you want the cranking settings in effect always while cranking. There's more here: http://www.megamanual.com/mt28.htm#so
