Alpha N and turbo's
Posted: Mon Jul 28, 2008 12:00 am
by pommie02
Can i use alpha n with a turbo setup on my bike ?
or will have to use a map sensor ect
Re: Alpha N and turbo's
Posted: Mon Jul 28, 2008 7:26 am
by SQLGUY
Unless you can some up with some custom software that can model and predict boost from your turbo on your engine, I think you're going to have to have MAP or MAF.
Don't know about ECT, though, but EGT might be helpful.
Posted: Tue Jul 29, 2008 3:35 am
by Dave Sloan
Does hybrid alpha-n work on the microsquirt? Thats what I am going to use when I get around to turboing my project bike?
Posted: Tue Jul 29, 2008 5:55 am
Yes it does work on microsquirt - same code as regular MS-II. You can use alpha mode at low rpm and MAP at high rpm - or vice versa if you wanted, and it blends the two in between. But I wouldn't run pure alphaN with no map sensor with a turbo - I would want something to tell the processor what the boost was.
Posted: Tue Jul 29, 2008 1:15 pm
by pommie02
i think the blending sounds good.-
it should give me a good starting point
