required fuel
required fuel
pommie02
Re: required fuel
download megalog viewer its a great program, it will help you loads.
have big are your are your injectors...and what size engine
Re: required fuel
pommie02
Re: required fuel
why dont you post up a msq file so someone can have a look at it for you
Re: required fuel
- Attachments
- megasquirt200809061250-961.msq
- (25.18 KiB) Downloaded 77 times
pommie02
Re: required fuel
what size are your injectors and engine size
Re: required fuel
pommie02
Re: required fuel
i thought they would be bigger than 90cc, my 750 ones are 240cc
Re: required fuel
johnbannell
Re: required fuel
If you are still having the RF problem, I think that you will find somewhere that the VR sensors cable is reversed polarity on the V1 Microsquirts (i eventually found the reference after I had sorted out the problem!). I found it out the hard way!!!! interference and resets everywhere. Solution? well I used co-axial cable for the coil leads with the screens tied to earth at the main earth point. I also managed to cut the VR sensor wires near the connector and re-reverse them. A simple way of checking your loom is to use a modern digital multimeter and see if there is a resistance between the end of the screen of the VR cable and ground. If there is less than 1 ohm you are OK and the loom has the correct wiring, If the resistance is higher (thinks several 100s of ohms) the loom is reversed. Even if the loom is OK the screened cables to the coils is a good solution.
J
