GM HEI 8 pin module with Microsquirt
Andy_Stprbeck
So possible stupid question but the GM HEI modules are one way to do this right? Is there some really obvious better way to do this that I don't know about?
If I use an 8 pin HEI module wired as shown here:
http://www.megamanual.com/ms2/GM_7pinHEI.htm
Except:
1. where this diagram says DB37 pin number 36 I would wire to Microsquirt pin 12 (Ignition output #1)
2. where this diagram says DB37 pin number 24 I would wire to Microsquirt pin 30 (optoin V+)
3. HEI module pin "B" on the HEI goes to Vref
4. Set ignition output jumpers in Microsquirt to logic level.
Questions:
1. To what would I attatch optoin V- ? I'm guessing the ground pin of the Module, together with another wire from ground pin on module to ground near battery with all of the other grounds? Or maybe optoin V- goes to nothing in this situation?
2. I have a single cylinder wasted spark setup, since this thing is good for 6000 rpm+ on a V-8 it should be good for well above the 10-11000 ish rpm of my single right?
3. My single tooth input is at 75deg btdc, so I can't use the cranking override thing, and I'm not sure what the advantage of that would be anyway??? So if I don't want to use it I can just hard wire to Vref rather than using the relay right?
4. Since the whole point of this is to minimize noise I would want the module mounted as close to the coil as possible so the wires from module to coil are as short as possible and as far from any other wiring as possible, right?
5. Using the connectors available for this module it should be pretty rugged, resistant to weather and some moderate heat. Right?
Thanks for any help
Andy
Re: GM HEI 8 pin module with Microsquirt
http://www.megamanual.com/seq/coils.htm
Andy_Stprbeck
I do kind of want to keep the original coil though. It is a coil on plug type coil and it is used to seal up the "hole" down into the cavity where the spark plug sits in the engine. Also, I figured I'd leave the option open to later attempt using the built in Microsquirt ignition drivers for a somewhat cleaner install, but to start out try to eliminate sources of trouble.
Just my 2 cents worth.
Read the last post in this thread, it explains everything about the internal coil driver problems.
http://www.microsquirt.com/viewtopic.php?f=87&t=23064
Andy_Stprbeck
1. Use the LS1 or LS2/truck coil
2. Use the Bosch 0 227 100 124 module
3. Use GM HEI module
4. Use any of the various coil pack type modules (EDIS, DIS, etc...) which doesn't make sense on a single
Only 2 and 3 keep stock coil which I kind of want to do,I found the HEI module on Ebay easier then the Bosch, and somebody posted in another thread that the GM module somehow seems to interpret the VR sensor signal "better" than the built in microsquirt circuit. I figured even if that's not true it's just another option.
Am I mistaken here?
Andy_Stprbeck
Maybe this is a good time to ask what the difference is between "CDI" and "inductive ignition"?
The wiring diagram for the bike shows the coiled wire inductor symbols for the primary and secondary coils of the coil so I think is the "inductive ignition" variety, but this is educational, good info to know.
I already bought an HEI module from ebay for ~$20, but if it doesn't do what I need I'd happily eat the 20 bucks and go the better route.
Just as a side note a CDI and an inductive coil will look the same in a schematic.
Andy_Stprbeck
Guess I should have asked abut this BEFORE I purchased the parts.
I'll look into the TL1000 wires, I think Honda 600 F2/F3 wires might have a seal type deal that might work too.
Now that this has been pointed out to me, out of curiosity I checked the Yamaha web site and it even lists the ignition type as CDI on the specs for this bike.
Thanks Old Guy, you probably saved me a lot of frustration, and possibly some fried electrical components.
