squirting a v-max-ignition to be sorted out first
Posted: Fri Sep 26, 2008 7:40 pm
by blvdblaster1200
ive been poking around in old posts and notice the v-max is kinda tricky getting the ignition worked out.contacted niels and he says he used a zener diode bridge and uses two pulses to set his up.also i have heard mention of a sequencer.would this be a candidate to use on the max?what do i need to do to set up an engine with a odd firing out of phase ignition?also need dimensions on the controller too. thanks loads mike
