Sequencer Update
Sequencer Update
I'm also going to source more pins locally for the A35 connector so I can run as many grounds as possible (read: overkill it!)
Has anyone gotten any closer to firing an engine yet?
Kris
- Site Admin
Re: Sequencer Update
Well my Honda F4i engine teststand is running pretty well on MicroSquirt - I am getting up to the 13,000 RPM readlinekrisr wrote:H
Kris
http://www.flickr.com/photos/33848833@N07/
So next weekend I will attempt a swap with the sequencer. I will first run with no cam sync, it should reduce to a microsquirt. I need to take the cam out and grind off some cam sync bumps in order to provide one sync pulse per 720 rev. So, I too may be a few weeks away from running an engine, so the contest is still afoot!
i have been through the simulated signals in a lot of detail, and it is outputting exactly as expected.
i underestimated how much more new wiring is required. dang nest. and it's a balance of wiring for 'proof of concept' vs. making permanent looms. well... right now i'm leaning more toward 'proof of concept' to make sure it works, so i get to do all this wiring again (hopefully).
Kris- great idea to get new pins so you can just plug in the wire directly instead of splicing. Man... those ampseal connectors are nice. VERY easy to swap around. *** edited to add: wait... you got a 12 foot loom didn't you? either way... i found that the pins come out and swap real nice, so when i do final wiring, i'm going to crimp new pins directly onto my injector grounds & coil signal wires.
ca434sbc4
I agree that loose pins would be easier to deal with and less expensive.
- Site Admin
I personally had a complete nightmare with loose pins on the ampseal. They look all nice when they are crimped, but when loose they are not easy to work with. Mainly getting the crimp part back into the ampseal. Tried the needle-nose plier route and butchered up 50% of the pins, even after doing hundreds of them. I have several different crimpers for various pins types but none worked 100% on the pins. The main problem is that the crimp ears are very long and they need to be crimped with the "B" shape. If you just fold over both ears and mash with pliers then there is ear parts remaining that prevents them from going into the bore of the ampseal. So you have to go and snip these off. It gets extremely old after the second crimping...ca434sbc4 wrote: I agree that loose pins would be easier to deal with and less expensive.
What I ended up doing was cutting off the crimp ears and soldering the wires
We can offer pins only, I just suspect it may become a support nightmare.
Maybe I'm misunderstanding the problems you were having.
With the Looms that came with the unit, I did some swapping. As per the instruction sheet for the ampseal, i pulled the red wedgie thing out, and the installed pins removed with a simple twist and pull. they reinserted into new holes with a click. slide the red wedgie thing back, and it was done.
Were all the provide wires crimped with an industrial machine rather than by hand? I did not do any new crimping with new pins; were those hard to crimp by hand?
I tend to agree with you there BUT I still would offer a "pin only" method for those that already have an MS2 system and are looking at maybe snipping the DB37 off and just re-terminating into the ampseal green side.Bruce Bowling wrote:We can offer pins only, I just suspect it may become a support nightmare.
Personally i'm going to be getting a heap of loose pins and crimping them myself with assorted tools I have (It's DIY boys!
I just want to reduce the splicing needed and don't mind crimping terminals. The sensor connectors are available in shell and pins.
Anyone willing to post a digikey part number for the shell and pins?? I think I found the shell but haven't been able to locate the pins.
Joe
Note: Just excited to get my hands on a Sequencer.
