NAW wideband controller inside the Microsquirt case
Andy_Stprbeck
http://www.14point7.com/Widebands/NAW_OEM/NAW_OEM.htm
and trying to fit it inside the Microsquirt case.
Seems like a guy could tap into the power, ground, and wideband signal wires right inside the uS case so the only extra wires would be for the wideband sensor.
Any suggestions on why this wouldn't work? Is there any danger of electrical noise from this device causing problems for the Us, or heat? Also any suggestions on a plug that would be appropriate for getting the sensor wires into the case. I figured I'd put it through the blank "back" wall of the Us case opposite of the ampseal for the Us.
Andy
