Yamaha R6 stick coils
- Master Squirter
Has anybody successfully used or got any info on using R6 stick coils.coil on plugs etc. I can get them to fire on the rig, although surprisingly I get more noise and tach trigger drops when using the Logic Level Outputs, which is cured by pulling the ignition amplifier wires away from all the others.
I am after dwell in msec and spark duration values, that won't cook the units. I have started at low values and tested for temperature rise, but hopefully there will be some FSAE car guys, who might be playing.
