alfa-n tunning?
supertuner
alfa-n tunning?
gboezio
Re: alfa-n tunning?
I have found out that on the datalog, the MAP shows the real MAP snesor value, but if you check the VE line you can see the forced VE valut by the Alpha-N table.
It would help a whole lot to set your throttle % in a logarithmic fashion, there is very little difference between 80 and 100 % and a whole world between 0 and 20 %, more like 0, 5, 10, 20, 50, 100, this will helps driveability a whole lot since it's under 20 % most of time.
