ver 3.3xx
800vtwin
ver 3.3xx
Post by 800vtwin »
Is there a date in mind that the next code release will be?
Re: ver 3.3xx
Hopefully sometime next week.
800vtwin
Re: ver 3.3xx
Post by 800vtwin »
Is there any fixes / changes etc, related directly to the microsquirt, rather than just the sequencer? (basically -is there any benefit to updating)
Re: ver 3.3xx
Off the top of my head, the injector timing is tooth based, so more accurate, the injector timing was fixed to operate coorectly with odd-fire engines, the VR sensing may be a bit more robust, you can apply cylinder fuel and ign trim to a sequential setup, which only applies to 2-cylinder engines for microsquirt. This version also has a better MAF PW calculation. It also has the start of some model-based code which interested people can try. I will release a comprehensive description of the changes next week.
800vtwin
Re: ver 3.3xx
Post by 800vtwin »
Thanks. Looks worth while updating.
I'm not sure if you have any relations with tunerstudio. I was just wondering if it will be updated at the same time or if i will have to wait until TS is updated to use the new code. (unless I go back to megatune temporarily)
Re: ver 3.3xx
You should just be able to place the new ini that will come with it into the TS project directory and ask TS to change the ini file. I have been using the sequencer with TS for all my recent testing.
Peter Florance
Re: ver 3.3xx
Post by Peter Florance »
I assume new firmware will be posted here?
Thanks!
