Cranking in wasted always
Posted: Sun May 09, 2010 6:55 am
I thought this discussion might have come up at one point, but not sure if a conclusion had arrived.
In my opinion, Sequencer should always be in wasted mode when RPM < cranking threshold. Including if it coughs a moment > threshold and continues cranking, should be wasted. The reason is that it will create a consistency with startup. Right now car will swap from wasted to seq even if motor never fires up.
Typically, car fires up right away, so it fires while still in wasted mode so that is how startup will be tuned.
In the event the car has fouled plugs, bad gas, or other mechanicals that cause hard starting.... the fuel will be wasted for first 8 signals, then it will change to sequential for continued efforts which can be totally different for various reasons (including subject to opening time settings, squirt timing - open or closed valves).
Any thoughts? Perhaps it can be an option, but I'd like to see it always like that - less check boxes instead of more options.
