Zetec idle settings
Björn the Bear
Zetec idle settings
Post by Björn the Bear »
Hi guys!
I've succesfully installed a Microsquirt on my Zetec powered Westfield but, although I've read the manual twice, I can't seem to get the basic settings for the idle control right and so the car starts, but starts to "yo-yo" in RPM and AFR right away until it dies.
I'm using a 1800cc Zetec Silvertop with original injectors and inlet manifold and using a wide band lambda sensor. Would somebody be willing to help me out with a .msq file for the same or simuliar setup?
Re: Zetec idle settings
Unfortunately, the only Zetec we've tuned lacked an IAC valve and we just cranked open the idle speed set screw. I'd guess the valve runs at ~300 Hz based on our experience with other Fords though.
Do you have a data log of it idling you could post along with your MSQ?
