microsquirt and ls2 coils
Pin B (Signal ground at sequencer).... Is this the sensor ground that my tps, map, temp sensors use?
also, is it acceptable to combine the signal ground wires for 2 coils, into a single wire back to the microquirt? ( assuming the signal ground is aka sensor ground)
Re: microsquirt and ls2 coils
The signal grounds are also probably best left as individual wires until they get to the block, to lessen the probability of interference. In your case with such short lengths its not a big deal.
