How to set Advance for #2?
I have read http://www.microsquirt.info/dualspark.htm but am still confused about what value I should set for "offset (advance) for #2 (degrees)", found under Ignition --> dual/multispark options in tunerstudio.
I have a 4 cylinder 4 stroke engine, even fire, wasted spark, single crank wheel input. My trigger offset is at 291. What should this value be?
See attached screenshot for my settings
Thanks!
Rich
Re: How to set Advance for #2?
If you have 2 sensors 180* apart, it will probably be set to 0*
trigger offset will set your overall timing in relation to your #1 pickup and trigger offset. If your second sensor is physically offset the right amount, the offset #2 will be 0
basically get your trigger offset right with a timing light on bank 1.
then check bank 2, if it is right with offset #2 at 0. then you are good. if not then adjust offset #2 to get your bank 2 timing light on the marks.
hope that makes sense
I verified with a timing light that 291 gives me what it should on bank 1 (commanded advance = measured advance).
Th #2 odd offset applies ONLY if you have an odd fire engine with a toothed wheel. It should be set to 0 even if you have odd fire but are using dual tach sensors, since the placement of the sensors takes care of the odd-fire part.
